LabWindows/CVI
Distribution error of my application over internet using zipped build folder
     I am having problems with the upload and download of a zipped distribution folder over the internet.  The distribution was created using LabWindows 8.0.1.  This procedure worked with distributions created using LabWindows 7.1 and now it does not work for 8.0.1.  Has anyone experienced a similar problem?
Carl Biver
(2,975 Views)
A distribution created in version 8.0 or later may be significantly larger than the equivalent distribution created in earlier versions of CVI because of a brand new, beefed up distribution creation framework introduced in 8.0. Are you hitting some upload/download size cap? Can you be more specific about the problems you are having?
Mert A.
(2,974 Views)
