LabWindows/CVI
Distribution kit relative paths
Using CVI 2013 SP2. When adding files to the installation path, I can't seem to figure out how to make the Source Path relative to the project directory. In the .cds file, all the files use the full path name. So if this project were built on another machine, the files won't be found. Surely there Is there a solution?
(1,018 Views)
When you move the project directory and then reopen the project file, all the paths are readjusted automatically, don't worry.
(962 Views)
