LabWindows/CVI
Dll with Uir in Visual C++
Hi all,
I'm using LabWindows CVI 6.0.
I'm doing some tests to move some code into Dll.
I succeeded to create a Dll in CVI that load a panel. It is correctly called
from CVI.
I succeeded to create a simple test Dll from crash with Visual C++. It is
correctly called from CVI.
I tried to compile the code of the Dll in CVI that load a panel under Visual
C++ 6.0 en have some problems:
As I'm loading panel, I need the followin include:
#include
#include
#include "mon_interface.h"
#include
I add the following lib path:
C:\Program Files\National Instruments\MeasurementStudio\CVI\include
I have got problems while linking:
Linking...
mon_interface.obj : error LNK2001: unresolved external symbol _CloseCVIRTE@0
mon_interfa
_InitCVIRTEEx@12
_DiscardPanel@4
_RunUserInterface@0
_DisplayPanel@4
mon_interface.obj : error LNK2001: unresolved external symbol _LoadPanel@12
Debug/dll_vc.dll : fatal error LNK1120: 6 unresolved externals
Error executing link.exe.
I manually added the following lib file: cvistart.lib
It does not help.
Have you got any idea???
Thanks in advance,
Sylvain
(3,371 Views)
You need to add the import libraries for the CVI runtime (cvirt.lib) and any libraries you are using to your project. These libraries can be found in the cvi\extlib directory.
Best Regards,
Chris Matthews
(3,371 Views)
Thanks a lot!!!
I also had to add the following lib files:
cviwmain.lib
cvisup.lib
Now, it is working.
Thank's again 🙂
Sylvain
"Chris Matthews" a écrit dans le message de news:
506500000005000000970A0100-1042324653000@exchange.ni.com...
> Best Regards,
> Chris Matthews
(3,371 Views)
