LabWindows/CVI
Do I have to un-install LabWindows/CVI 8.01 to install 8.1?
We just received: (label on the box)
"Upgrade, Labwindows/CVI Full Development System, Version 8.01 to Version 8.1 for Windows 2000/XP"
The "Labwindows/CVI Release Notes" document included says to un-install 8.01 before installing or install in a different directory.
Given this is an upgrade is it really necessary to un-install Version 8.01 first?
If so what about my NI-DAQmx stuff?
Kirk
(3,173 Views)
Kirk,
You don't have to uninstall 8.0.1 first. You can have both 8.1 and 8.0.1 installed in the same machine. But you can only use some drivers, such as DAQmx, from one of the installations. So, if you want to use DAQ from 8.1 (and not 8.0.1), you'll have to upgrade or uninstall/reinstall the NI-DAQ product. When you do, it should automatically install to your CVI 8.1 installation.
Luis
(3,150 Views)
Hi Kirk,
If you would like to keep support for DAQmx for both versions of CVI, the following KnowledgeBase article will help:
Installing DAQ Support for Multiple Versions of LabWindows/CVI
Cheers,
David Goldberg
Software R&D
(3,144 Views)
