LabWindows/CVI
Do I need previous CVI installations?
I just installed Labwindows/CVI 8.1.1.  I now have the following directories under C:\Program Files\National Instruments\LabWindows\
CVI71
CVI80
CVI81
I ran CVI81 and it worked fine.  It brought the configuration over from CVI 8.0.1 so I think I'm all set.  I'm pressed for space on my hard drive and
would like to know that it's okay to remove CVI71 and CVI80.
When I Add/Remove programs on National Instruments I see the following programs installed (along with a bunch of others of course )
NI LabWindows/CVI 7.1    FDS Package (can I remove this one?)
NI LabWindows/CVI 8.0.1 FDS Package (can I remove this one?)
NI LabWindows/CVI 8.1.1 FDS Package
NI LabWindows/CVI 8.1.1 Run Time Engine
Can I uninstall the first two without any complications?  I just don't want to mess anything up.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(2,975 Views)
Every CVI installation is independent from the others, so you should be able to uninstall previous installations of CVI without problems.
(2,971 Views)
