LabWindows/CVI
Do we need distribution licence for Imaq Vision
Hi...
I'm developping CVI ... since many years... now on version 7.0... I want to know if we need a special distribution licence for Imaq Vision...  I have Version 6... I think
When I create a distribution kit... and install it on the other computer... do not work...
Regards
Steph
(3,158 Views)
Hello Steph,
Thank you for contacting National Instruments.
Application deployment with the Vision Development Module is based on single-seat licensing. This means that an individual license is purchased and activated for each deployment of your Vision application. The Vision Run-time Engine is universally used to execute the application, but methods of deployment and available packages differ between versions of NI Vision.
Deploying Applications Using Vision 7.1.1 and Earlier
The IMAQ Vision Deployment Engine (P/N 778044-01) is a disk containing the Vision Run-time Engine. To run a deployment application, install the runtime engine on the target computer.
A single-seat Vision Deployment License is required for each target machine you install the Run-time on. One license (serial number) is provided with the Vision Deployment Engine, so you can deploy your application to one target computer. To deploy to more targets, you can purchase more Vision Deployment Licenses (P/N 778044-00).
Mike T
(3,134 Views)
