LabWindows/CVI
Documentation Tags won't show up
After finding out that these tags could be used for user generated functions I wanted to start using them in my code. I can see the tool-tip help in the library functions but not in mine. Even after compiling, building etc...
Is there some option/setting that has to be configured to see the tool-tips for my functions??
These are the sites that I used as reference to try and figure out this problem.
http://www.ni.com/tutorial/6502/en/
https://forums.ni.com/t5/LabWindows-CVI-User-Group/LabWindows-CVI-Tip-Generate-Documentation-for-you...
(2,731 Views)
Duplicated post: see discussion here
(2,421 Views)
