LabWindows/CVI
Documentation tags and static functions
I'm an issue with the documentation tags.  It appears that if the function is declared as a static function, it won't show up in the generated documentation (I'm using HTML).  For example:
static int ArrayLocation(int i1, int i2, int num_coeff)
Will not show up, but if I remove the 'static' keyword then the function will show up in the generated documentation, i.e.:
Thanks for any help with this.
Message 1 of 1
(2,866 Views)
