LabWindows/CVI
Does DAQ_Check return only even numbers for samples retrieved?
I am using the function DAQ_Check to monitor the progress of my data acquistion. I noticed in my program that the number of samples retrieved is always an even number. Here is some code that is similar to what I am using:
short gain[1] = {1};
short channel[1] = {1};
short double_buffer[8000];
unsigned long points=0,check[2000]={0};
int loopcounter=0;
short code,stopped;
Init_DA_Brds (1, &code);
AI_Configure (1,-1,0,10,0,0);
DAQ_DB_Config (1,1);
SCAN_Setup (1,1,channel,gain);
SCAN_Start (1,double_buffer,8000,3,10,-1,0);
while (points < 250) {
DAQ_Check (1,&stopped,&points);
check[loopcounter++]=points;
The array check will hold the values 0,0,0,0,2,2,2,2,4,4,4,4, etc
Do I have a mistake in my code or does DAQ_Check only return even numbers? Is my program actually acquiring two points at a time? I want to acquire one point at a time at even intervals.
(2,935 Views)
I would suggest you to take a look at one of the examples on double buffered analog input operation to see the proper flow of commands. I do not think DAQ_Check returns just the even values. Here in this case it might be because it might be loosing the odd ones.
So I think it is a good idea to take a look at example program is a good idea. They are available at C:\Program Files\National Instruments\NI-DAQ\Examples.
Also check out the flowcharts available in NIDAQ User Manual .
NIDAQ User Manual
Also, you can take a look at examples that use DAQ_Check functions by going to C:\Program Files\National Instruments\NI-DAQ\Docs\nida
ex.hlp
and selecting examples by "NIDAQ functions used".
Please do let me know if you have any further questions.
Sincerely,
Sastry V
(2,935 Views)
