LabWindows/CVI
Does Labwindows CVI version 10.0 program written in windows XP work in Windows 7
I have written a LABWINDOWS CVI version 10.0 program in the Windows XP enviroment. The program communicates
via Ehternet interface with NI cDAQ-9188.
Can I use the same program in the Windows 7 environment?
Bobby
(4,743 Views)
Hello Bobby,
To the best of my knowledge, you shouldn't have any trouble running your program in Windows 7. According to this article, LabWindows 2010 is compatible with Windows 7:
http://www.ni.com/lwcvi/product-lifecycle/
Are you running into any specific challenges moving to a different system? The only serious concern I could see is if you were using a driver in your program that is not compatible with Windows 7. If you'd like more specific help, any further description of your application would be helpful.
Collin D.
Software Product Manager
(4,718 Views)
Thank you for the answer. We use NI hardware but use the RS232 interface program in the CVI to communicate to
2 external devices.
Thanks again
Best Regards
Bobby
(4,712 Views)
Hello Bobby,
Do you have any more information regarding the RS232 interface program? If that program is compatible with Windows 7 and you aren't using any other drivers, you should be able to upgrade without issue.
Collin D.
(4,686 Views)
Hello Mr Collin,
The RS232 program used is from a LabWindow CVI example program. It uses the CVI library files related to the
standard RS232 port.
The Main program communicates with the NI cDAQ-9188. I use a function call inside the CVI Main program to
communicate with an external device through the computer's RS232 port. The function call is just a RS232 example from the
CVI programs that I modified.
Bobby
(4,678 Views)
Hello Bobby,
I would assume that Windows 7 and Windows XP handle serial communication the same way. Because of this, unless there are additional code modules that might only be compatible with XP and not with Windows 7, I would assume you should be fine when you upgrade. Feel free to post back if you start experiencing issues after the transition.
Collin D.
(4,672 Views)
