LabWindows/CVI
Does Labwindows/cvi support the statement: _T("")
It seems that the complier doesn't support the statement like _T(""). Does there exist any method to solve this problem?
Thank a lot.
(3,338 Views)
_T macro is used in languages that support UNICODE strings: depending on whether _UNICODE macro is defined, permits treating all strings as unicode os simple ansi strings. Considering that CVI does not support unicode strings you should consider removing it from your code.
Message Edited by Roberto Bozzolo on 02-20-2008 10:32 AM
(3,323 Views)
Or you could just do:
#define _T(a) (a)
at the top of your code.
Martin
Certified CVI Developer
(3,311 Views)
