LabWindows/CVI
Does NI 6251 PCI support acquistion of DIO using a Digital/Analog trigger
Hi, does NI PCI 6251 support acquisition of DIO using and analog/digital trigger.
When I try creating a task to acquire a DIO in Measurement & Automation Explorer the trigger field's are
not active.
-Charles
(3,413 Views)
Hi Charles,
NI PCI-6251 does not support digital or analog trigger when using digital I/O. If you want to use a trigger you will need to use analog I/O.
Ima
Applications Engineer
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(3,396 Views)
