LabWindows/CVI
Don't have nican.lfp of nican.fp files in CVI71 folder
I have been installed CVI version 7.01 without uninstalled CVI version 6.0 (I have both,and all installed with the same login user).
And I have updated the NI-CAN version 2.2.
In the "Library >> Customize...", the NI-CAN library is checked, but the
"Library" >> NI-CAN is not selectable (it is gray).
When i compil my software with CVI7.0, the compiler doesn't find nican.h file.
And I don't have this problem with CVI6.0.
The folder "\Measurement Studio\CVI\bin" only have nican.fp file.
And The folder "\CVI71\bin" doesn't have the files nican.lfp and nican.fp. Is it normal?
And how can i to have NI-CAN library selectable (and not gray) in the "Library" menu? and
to not have problem of compilation?
(3,150 Views)
I'm not entirely positive about this, but I'm pretty sure you can only have one version of the "NI-CAN for CVI" files in your computer, regardless of how many installations of CVI you have. This is because these files are installed as part of the NI-CAN driver, not CVI. And you cannot have side-by-side installations of the driver.
So you can only "fix" this by doing something which will remove the NI-CAN support from CVI 6.0 and add it to CVI 7.1. If that is what you want to do, you can do it by uninstalling NI-CAN from the Add/Remove Programs in your Control Panel, and then reinstalling it. When you reinstall it, it should automatically install the files in CVI 7.1 -- it picks the latest version of CVI it finds.
Luis
NI
(3,144 Views)
