LabWindows/CVI
DoneCallback event not called for NumSample > 1M
Hallo,
The system I am working with is a PXI with two modules: PXI-6433 and PXI-6422.
I am facing  problem when I try to acquire more than 1 milion samples per channel, basically the DoneCallback event is never called and the system is just waiting to finish its endless task.
The basic commads I use are:
DAQmxErrChk (DAQmxCreateAIVoltageChan(ai_Handle,txt,"",DAQmx_Val_Cfg_Default,-scale[i],scale[i],DAQmx_Val_Volts,NULL));
DAQmxErrChk(DAQmxCfgSampClkTiming(ai_Handle,"",SamplFreq,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,NumSampl));
DAQmxErrChk (DAQmxRegisterDoneEvent (ai_Handle, 0, DoneCallback, NULL));
The system is working fine as long as the NumSampl in the second command is <= 1.000.000
Is there any limitation to the number of sample / dimention of the analog input buffer?
Any possible solution to this problem?
Any help is apprciated.
Nicola.
(3,613 Views)
*bump*
(3,587 Views)
Are there any updates on this? I just ran into exactly the same problem with my PCI-6120 board (which has 64 MSample on-board memory, so that should be OK). I use a windows XP machine with the most recent driver set (Ni-DAQmx 8.8).
(3,405 Views)
