LabWindows/CVI
Doubst with the function Scan and the Toggle button
I have some doubts.
When it uses the modifiers [in] or [wn] in the function Scan, instead of "n" , cans it use a variable?
For example instead of
Scan (Target, "%s>%s[w1]",Target2);
Scan (Target, "%s>%s[wNumber]",Target2);
where Number is a variable.
Second doubt.
In Visual Basic, when you put
some options button into a frame every time one of them is chosen (when it
runs), the rest is unselected. Is there any way to do the same in
LabWindows/CVI 5? or every time one of them is chosen the rest has to unselected by code.
Thank you very much for yours answers.
(3,391 Views)
As per your first question, I suggest you to read this paragraph in the CVI Formatting and I/O Library manual:
'Scan, ScanFile, ScanIn�Asterisks (*) Instead of Constants in Format Specifiers'; inside it you should find the answer to your question.
With regard to option buttons, in CVI there is no native equivalent to this VB control: you will have to do it programmatically by yourself or use this useful instrument driver available in the Development Library: "Independent Sets of Radio Buttons in CVI",
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/2eec01d3aeecea2b852563ff006c1076?OpenDocument
Hope this helps
Roberto
(3,391 Views)
Thanks Roberto.
"Roberto Bozzolo" escribió en el mensaje
news:506500000005000000A4A90000-1031838699000@exchange.ni.com...
'Scan, ScanFile, ScanIn-Asterisks (*) Instead of Constants in Format
Hop
e this helps
Roberto
(3,391 Views)
