LabWindows/CVI
Draw a horizontal line on a stripchart
I have a stripchar, Y-axis range is 2 ~ 5, X-axis is -60 ~ 20,  I'd like to draw a horizontal line with Y = 3,
what's simplest way to do that? Any example is available?
(4,481 Views)
You could add a point with a constant value...
(4,478 Views)
Could you give me an example? The line could be in anywhere within the range.
(4,366 Views)
Something along the lines of:
char array[80];
int i;
for(i = 0; i<80; i++){
       array[i] = 23;
PlotStripChart (panel, PANEL_STRIPCHART, array, 80, 0, 0, 0);
Will produce a line that is 80 points long (-60 to 20)
(4,341 Views)
