LabWindows/CVI
Drawing and plotting with different results
I am plotting a bitmap on a graph control and then ad several plottings to the graph to display results of a performed image analysis. To approve these results I first drew them on the image before plotting it. Know the plots sometimes differs from the drawn points and shapes. In my case the drawn points are the same as the plotted near the center and differ in 1 pixel (x+y) near the borders, also circles and rectangles are not exactly congruent. Does anybody have an idea?
cheers
(3,211 Views)
Hello DocEye,
From your message, I couldn't quite understand your setup. Could you clarify the problem you are seeing?
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,188 Views)
Check out the response by LuisG on this post.
Bilal Durrani
NI
(3,177 Views)
