LabWindows/CVI
Drawing vectors on screen at nearly eaxcat angles
I would like to create a Labwindows CVi app that will draw Lines(vectors) at specified angles.
Example
                      90
                        I
                        I
0                      I                     180
and then at 30 and 43 or 57 degrees.  or what ever angle the user enters.
What display would you use, picture , canvas, graph or strip chart?
Thanks for the insite.
(2,967 Views)
It depends on whether or not you want to draw just a static image once, or if you need to remove one already drawn line and replace it with another. For the first case, I would use a Canvas. For the second, I would use a Graph, since this will return plot handles for each drawn item, giving more control.
JR
(2,956 Views)
