LabWindows/CVI
Drivers oscilloscope nedded
Is it possible for you to forward to us the driver and the
instructions for an oscilloscope preferably Tektronix 2012? We have LABview 7.0. We downloaded "tktds1k2k_lv70" but we have no idea how to use it. We need the virtual scope.
Thank you very much.
(2,832 Views)
For instructions on how to use your instrument driver, check out: Plug and Play Instrument Driver Installation Instructions.
Following these instructions will allow you to use the driver in LabVIEW. Once installed correctly, you can use the driver by navigating to it's function palette in a block diagram. Right Click >> All Functions >> Instrument I/O >> Instrument Drivers. There should be a sub palette for your oscope, and in the sub-palette, you should be able to find a "Getting Started" VI of some kind. You can just place this down in your block diagram, or you can open up the front panel, and use the VI on it's own. From that point, you should be able to use the code in the examples as a starting point for you own application.
Good luck!
Logan S.
(2,815 Views)
