Hi
My group and I are currently doing a project which requires the transmission
of wireless ECG signal
to labview. The components which we decided to use complete the task are:
2 x Xbee (Zigbee S1) modules,
1 x Arduino uno
1 Xbee module attached to the Arduino had been programmed with Arduino
. However, due to our
lack of understanding of how Arduino functions, we are unsure if the co
ding for the interface is valid
for transmitting the Analog ECG signal wirelessly to the other Xbee mod
ule connected (USB cable) to
the computer and later displayed onto waveform using labview
The coding used is as follow:
#include "LabVIEWInterface.h"
int dato =0;
const int analogInPin = A0;
int sensorValue = 0;
void setup()
Serial.begin
(9
600);
void loop()
sensorValue = analogRead(analogInPin);
Serial.println(sensorValue);
delay(1);
checkForCommand();
dato = analogRead(0);
String cadena ="S0>";
String cadena1 = cadena + dato;
Serial.println (cadena1);
delay (10);
if(acqMode==1)
sampleContinously();
We have construst the labview that attached, but we are unclear which works for the coding
as stated earlier in the post.
We hope to get some enlightenment.
Thank you.
