LabWindows/CVI
EVENT_KEYPRESS Trigger.
I have a text string control that I use to enter text and then when I press the <Enter> the text is sent out an RS232 comm port.
Is there a way to sent each character immediately after it is entered into the text window instead of waiting for the <Enter> key?
I want to emulate an RS232 comm port.
For example if I enter abcdf\befg
it would do the following:
ComWrt (comPort, buf, 1); // Where buf = "a"; ComWrt (comPort, buf, 1); // Where buf = "b";
ComWrt (comPort, buf, 1); // Where buf = "c"; ComWrt (comPort, buf, 1); // Where buf = "d"; ComWrt (comPort, buf, 1); // Where buf = "f"; ComWrt (comPort, buf, 1); // Where buf = "\b"; ComWrt (comPort, buf, 1); // Where buf = "e"; ComWrt (comPort, buf, 1); // Where buf = "f";
ComWrt (comPort, buf, 1); // Where buf = "g";
When there is more than one character I might have to read the string  GetCtrlVal (gPanelHandle, PANEL_TX_STRING, buf) and only send the last one?
Thanks for any help.
(3,699 Views)
This is more readable.
(3,698 Views)
it seems the message title contains the solution you are searching for: EVENT_KEYPRESS is triggered each time you press a key when a control has the focus. have you tried it ?
(3,686 Views)
Yes I am using it now. I just wanted to make sure that I was implementing this in the correct way. Sometimes the obvious isn't necessarily the most appropriate.
Confirmation always helps.
Thanks.
(3,682 Views)
