LabWindows/CVI
EVENT_LEFT_DOUBLE_CLICK in indicator mode
Hello all,
I'm a bit surprised that the EVENT_LEFT_DOUBLE_CLICK event isn't called when
a numeric is in indicator mode. Why is that ? I mean it has nothing to do
with changing the value.
Is there a list of possible events per control style, classified with the
various states of the controls (hot, indicator, dimmed, etc) ?
Also, in the user interface editor, I used to be able to see, in the upper
right corner, the events called when using the 'operate tool'. That is no
longer the case. Am I missing something here ?
Guillaume Dargaud
http://www.gdargaud.net/
(3,137 Views)
Starting from CVI2009 (I suppose: I haven't used CVI9) event indication has been moved to the status bar at the bottom of the screen: as you can see in this picture, content of eventData variables have been added, which can be usefult in some case.
On my machine (CVI2009 SP1) EVENT_LEFT_DOUBLE_CLICK is fired on indicator numerics too.
(3,135 Views)
Hello Roberto,
Hmmm, I don't see this status bar (I'm with CVI2010).
I'm using the environment in multiple windows mode (or whatever it's
called), maybe that's the reason. How do I switch to the full window mode
again ?
Guillaume Dargaud
(3,131 Views)
View / Workspace View Selection
(3,129 Views)
> again ?
I confirm that this status bar is missing in 'classic workspace view' but
present in the 'integrated view'.
Also , if I switch to 'integrated view' so I can use it and then back to
'classic view', all my window positions and sizes, which I've been fine-
tuning over months (and I'm not even kidding), are lost. I HATE that.
As for the missing double-clic, it was my own bug.
Guillaume Dargaud
(3,123 Views)
