LabWindows/CVI
EVENT_SORT for table control
the built-in sort popup of a table control is quite convenient, allowing to sort columns without any programming Smiley Happy However, imho it would be useful to allow notifying the program of such a sort event. It appears though, that the EVENT_SORT is available only for tree controls... As a consequence, if I would like to be notified I need to use the function SortTableCells and do everything myself.
Is there a more convenient workaround?
And just out of curiosity, why is there no sort event for the table control?
Wolfgang
(3,056 Views)
You could use a tree instead. You can configure a tree with multiple columns to look like a table. Check out the attached uir.
(3,051 Views)
Thank you, jared, for the visual comparison!
For the short term this is not an option for me - I have just started to familiarize myself with the table control, and the tree control seems even more complex... It appears to be a superset - is there anything that the table control can do what the tree can't achieve?
For the not so short term I have filed a product suggestion here
Thanks, Wolfgang
(3,026 Views)
