LabWindows/CVI
Edit Picture / Quick Edit Window
I have a panel with a picture. When I click on the picture, the Edit Picture window appears. I do not have the original picture file. How can I get it from the Quick Edit Window ? I have to modify the image.
Please see the attached file.
(3,072 Views)
You can create a little program that:
1. Loads the panel
2. Calls GetCtrlBitmap to obtain the bitmap
3. Saves the bitmap with SaveBitmapToXXFile (use the type you prefer)
(3,069 Views)
