LabWindows/CVI
Editing a project causes project tree display to reset display settings
Could you please check if you can re-create the same effect (I can observe same behavior both on CVI 2015 and 2020):
  • Right-click the project name on your project tree and select Edit Project... menu item
  • Edit Project popup appears
  • Add/remove files to/from your project
  • Click OK to close the popup
  • Project tree display properties revert to some different format (I use dark background and yellowish font color, it becomes white background with black and different font types)
  • Restarting CVI fixes problem
S. Eren BALCI
IMESTEK
(1,235 Views)
I tried it, and mine did the same (v2020).
I think maybe it's because the project changes have not been saved.
I switched to another project then back again, and the project tree looked normal again.
(1,190 Views)
Thank you for confirmation.
This is not a project setting. It is an environment setting.
So it should stick.
I think that's a bug. But I didn't check whether it is a known issue or not.
Maybe someone from NI will clarify.
S. Eren BALCI
IMESTEK
(1,175 Views)
