LabWindows/CVI
Editor window does not have colors
Hi
One of my CVI installations (8.01) has no colors in the editor window.  The tree section does have colors.  I have no idea how it happened.  Anyway, I went inot Option-->fonts and sets the default.  Still the same!
Any idea how to bring it back to normal...
Rafi
(3,290 Views)
Have you checked the "Colors..." settings in the Options-Menu?
(3,277 Views)
yes....colors option is set correctly
Fonts are set correctly.
What else can it be?
(3,263 Views)
Could you check if the "Syntax Coloring" option under Options menu is checked?
Shakhina P.
(3,244 Views)
