LabWindows/CVI
Ellipsis in HIPAR documentation
I have got a function which has an ellipsis ("...") parameter.
When I try to write a documentation for this parameter
/// HIPAR .../Helptext
I get the Warning: Missing or invalid argument for documentation tag.
It must work some way because printf etc. show popup help for the ellipsis parameter.
Thanks in advance for your help.
(3,291 Views)
Hello
I am sorry, but I don't really understand what you are trying to do and what you exactly are looking for. Could you develop your problem a little more?
Regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(3,252 Views)
This is an example code:
7382   /// HIFN  Function to demonstrate popup help in CVI
7383 /// HIPAR ParA/This is the first parameter
7384 /// HIPAR ParB/This is the second parameter
7385 /// HIPAR ParC/This is the third parameter
7386 /// HIPAR .../This should be the description for the ellipsis parameter ("...")
7386 /// HIRET This function returns allways 0
7387 int FuncX(int ParA, double ParB, char * ParC, ...)
7388 {
7389
7390 return 0;
7391 }
When I compile my project include this code I get the following warning:
  7386, 11   Warning: Missing or invalid argument for documentation tag.
This means the compiler does not accept "..." as parameter name.
Question: What do I have to write instead of
/// HIPAR .../Parameter description
that the compiler knows which parameter is mentioned in this documentation line?
(3,244 Views)
