LabWindows/CVI
Enumerating COM port in CVI programming
Using VISA can find the hardware resources. I'd like to know excepting VISA, is there any way to do this?
David
(4,420 Views)
I imagine you should find some informations deeply digging inside the registry or SDK functions provided you know how to search, which I don't know.
Maybe the simplest thing at all it to try opening the com ports in a loop and monitor the resulting error code: this operation should take only a few seconds to perform since you are not actually performing any I/O operation on the ports in this moment.
(4,410 Views)
I have used the loop method for years. Here is part of my code.
comstring is defined as a 2 dimensional string array of the ports so that comstring[1]="COM1",comstring[2]=COM2", thru "COM32". portarray[ ] is an integer array, size 33. When the loop is done portarray[x] will contain 1 if COMx exists on the PC, 0 if it does not.
        for(i=1;i<33;i++)
            comstatus=OpenComConfig (i, comstring[i], 9600, 0, 8, 1, 512, 512);
            if (comstatus!=0)
                //FAILED
                portarray[i]=0;
            else
                //OPENED
                portarray[i]=1;
            CloseCom(i);
(4,405 Views)
It's not very easy to do in CVI. I have written a DLL that you can use to find all the COM ports in a system (or ones with particular names). You will find it in this thread.
Martin
Certified CVI Developer
(4,391 Views)
