LabWindows/CVI
Enviroment configuration file for PC-Lint (Gimpel) and LabWindows
I'm using LabWindows/CVI 6.0. I'm looking for a configuration file
(e.g. cvi.lnt) to suit PC- Lint (Gimpel Software) to the requirements
of LabWindows/CVI.
Does anybody have such a file or knows a link to its source?
Thank you.
Mario
(3,304 Views)
Hi Mario,
Here's what I ended up doing:
Neither CVI nor Raisonance (my 8051 compiler) has a hookup for PC-Lint, but Keil's MicroVision IDE does. You can download Keil's IDE and for free and use it as a "base" for PC-Lint -PC lint will be using Keil's editor. Keil's IDE has a 4K restriction on code you can compile for free with it (it's used for 8051 embedded programming), but there is no limit to using the editor - you can do all your PC-linting through that. www.keil.com.
Judy H.
(3,304 Views)
