LabWindows/CVI
Equivalent of the "GetInQLen" function with Windows SDK?
Hey,
I have a code which used the RS232 CVI library but now I want to use the Windows SDK one. My problem is to find the equivalent of the "GetInQLen" function. For the moment I am using the "GetCommProperties" and the associated structure but the result is the max size of the input buffer and not the size of the message.
Do you have any solution to my question?
A French guy.
(3,587 Views)
Bonjour,
regardez plutot dans la struct
COMSTAT, le champ "cbInQue"
"Specifies the number of bytes received by the serial provider but not yet read by a ReadFile operation"
Pourquoi ne pas utiliser CVI ?.
(3,587 Views)
Je m'ai posé la même question, pourquoi pas CVI? -Azucena
(3,587 Views)
tu parles aussi français ....c'est trés bien !
(3,587 Views)
moi, j'essaie d'eviter microsoft si possible.....
(3,587 Views)
Ce n'est pas ma langue maternelle, mais oui je le parles depuis longtemps 🙂
(3,587 Views)
