LabWindows/CVI
Erase the Scrren from a Strip Chart
Hello
i will erase the Scrren from a Strip Chart
(3,651 Views)
There is no one function call that is intended to do this, but there are several actions which clear the data from a strip chart as a side effect. For example, changing the axis range will accomplish this.
So, if you want to clear the screen, try calling SetAxisScalingMode with a new range. You can then call it a second time with the original range to return the axis to what it was before.
Luis
NI
(3,645 Views)
(3,639 Views)
What about ClearStripChart() ?
(3,629 Views)
Thanks too.
It's better.
(3,626 Views)
Duh, I'd completely forgotten about that function. Sorry about that!
Luis
(3,614 Views)
