LabWindows/CVI
Erreur -200220 niDAQmx
Hello
I have developed an application on a machine and it have to run on another one. This application is using a 9188 chassis with 9201, 9217 and 9401 nmodules
On the developpement machine I have created the tasks with MAX for temperature mesurement and digital output (9401 module). the soft is perfectly working. then I have created a distribution kit to install it on the other machine and the installation went on well. But when I run it I have the -200220 error "Device identifier is invalid".
Here is the par of the code where the error occure.
	ErrDAQ=DAQmxCreateTask("", &gTaskHandleCmd);
	if (ErrDAQ!=0)
		DAQmxGetErrorString (ErrDAQ, strErr, 256);
		MessagePopup ("Erreur DAQmxCreateTask", strErr);
	ErrDAQ=DAQmxCreateDOChan(gTaskHandleCmd, "cDAQ9188-1585BFAMod1/port0/line0","MAFVoie1", DAQmx_Val_ChanPerLine);
	if (ErrDAQ!=0)
		Fmt (Entete, "Erreur DAQmxCreateDOChan MAF1 %d", ErrDAQ);
		MessagePopup (Entete, strErr);
	ErrDAQ=DAQmxSetChanAttribute(gTaskHandleCmd, "MAFVoie1", DAQmx_DO_InvertLines, 0);
	if (ErrDAQ!=0)
		Fmt (Entete, "Erreur DAQmxSetChanAttribute MAF1 %d", ErrDAQ);
 If some body has an idea
(3,412 Views)
Please check this document : http://digital.ni.com/public.nsf/websearch/001DA4DB6A31CF8886256D33006FA857?OpenDocument#200220
You have to be sure if your device is present with MAX or you should check if you have change the device ID.
Celine
National Instruments France
(3,388 Views)
It is working now. To solve the problem I have imported a nce file where I have put my chassis in the distribution kit.
When I have installed the soft with this new distribution kit it have installed the drivers.
(3,383 Views)
