LabWindows/CVI
Error Building LW 2010 Distribution Kit
I get the following error when trying to build my distribution kit on a factory test set PC.  The same kit will build on my work laptop.
I have found various posts of similar problems building distributions with LW, LV, Test Stand, etc. but none are exactly like this and none of the other solutions has worked.
Ray
(3,360 Views)
Hi rayt52,
Looking at a similar report of this error, I am wondering if there is a difference in software installed on your machine from your laptop to your test machine. Specifically it looks like the NI Security Update has not been included. There were a couple of knowledgebase articles specific to this particular update indicating its importance, especially for pre CVI 2010 SP1 runtimes.
I am guessing this update is missing on your factory test machine. You can find more information on the mentioned update with these two articles:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019WwxSAE&l=en-US
Hopefully that may help get things moving along for you
James W.
(3,345 Views)
Thanks for the reply.  I managed to resolve the problem by installing the LabVIEW 2009 Run-Time Engine (SP1).  My laptop has LabVIEW 2009 FDS and although I checked for the distribution to install the RTE, there must have been a mismatch in registry keys, or installation files location or something that the test set didn't think it had the right installation.  Anyway, test set is now able to build the distribution.
Ray
(3,343 Views)
