LabWindows/CVI
Error Ordinal Not Found when launching a CVI executable
I try to switch from WIN7 to WIN10 on a TEST computer.
The program start correctly under WIN7.
After a good compilation (CVI 2010) of the Main executable under WIN10  and all used dll, I have an issue when I launch the executable. (see attached pi
I don't understant what is expected by the executable.
Thanks for your support.
Fred
(2,765 Views)
Did you try with a newer version of the CVI runtime, e.g., CVI 2015 which should work? Officially, CVI 2010 does not support Windows 10.
(2,750 Views)
