LabWindows/CVI
Error:Out-of-bou​nds pointer argument CVI12.0 Cannot access data member of a nested structure
I'm getting an error "FATAL RUN-TIME ERROR:   Out-of-bounds pointer argument (before start of memory block)" while trying to access a data element from a nested structure (structure with in a structure) in a dll file in debug as well as release mode.
I'm using CVI 12.0, and i came across some messages in the forum stating that similar erros was there for CVI 8.0, 8.5 & 9.0 but not 8.1. posted message
A previous  Message posted some time back  clearly explains the issue for CVI 9.0, but i don't know whether the isuue still persists for CVI12.0 too.
Will be helpful  if somebody can throw some light regarding the above mentioned issue;
Thanks.
(3,378 Views)
As you can see here this issue has been fixed in CVI 9.0.1
(3,372 Views)
