LabWindows/CVI
Error compiling resources.
I'm developing an App in CVI that uses NI-Daq as well as Imaq. When I compile it on certain machines, but not on all machines, I get the following error: "Error compiling resources. Make sure you tmp directory is writeable and not full."
(3,824 Views)
Hello
It might be because of a corrupt icon file. Try using the default CVI icon file with your project. You can find this in the project window under Build >> Target Settings.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,824 Views)
bilalD,
I tried your suggestion but that didn't help either. Anymore suggestions? The software worked before I installed Imaq...
Scott
(3,824 Views)
If this is a problem that was introduced by IMAQ, you might try going to ni.com/ask, and then asking to talk to an Applications Engineer, they might be able to help you get to the bottom of this problem alot faster
Bilal
Bilal Durrani
NI
(3,824 Views)
