LabWindows/CVI
Error creating .NET controller
Hello all,
I'm trying to create an .NET controlelr to the new Agilent VSA software. the "asemblies" are devieded to several files and i mange to create the controller to some of them but, for the most important one i get this massage after "renaming window" :
"Error occured while generating .NET controller code. Object reference no set to an instance of an object."
intuition tells me this could happen because this DLL contains a lot more functions then others i have tried....
thanks....
(3,668 Views)
Hi cfiroo,
Are you able to access the assemblies in other .NET supported software like Visual Studio?
Hassan Atassi
Director, ni.com
(3,649 Views)
havnt checked but they work since there is a translator frame work that uses them.
other asemblies of the same application work and generatre controllers.....
(3,644 Views)
Hi cfiroo,
Can you expand on what you mean by the "renaming wondow" (perhaps through a screenshot)?  Would it also be possible to get a screen shot of the error and maybe also an attachment of the assembly?
Hassan Atassi
Director, ni.com
(3,633 Views)
