LabWindows/CVI
Error: fCall undefined in IVI driver
We installed CVI 8.0 on a new system.  We copied in a project that ran fine under CVI 7.0. We are unable to successfully complile the project because of the error: fCall undefined.  This is used in a macro for an IVI instrument driver and is part of IVI.h.
(3,154 Views)
We still need help to solve this problem. Project is on hold!
Thanks everybody in advance.
Virgil
(3,129 Views)
Hi Virgil,
After installing LabWindows/CVI 8.0, you will need to reinstall the IVI driver to add the functionality to the new version of CVI.  If you are using the IVI Class drivers, then you will also have to reinstall the IVI Compliance Package to get that functionality in the new version.  Have you done this already?
If not, try this and let me know if it fixed the problem or not.  Have a great day!
Chris R.
Chris R.
(3,124 Views)
Chris, thank you. Problem solved with your help.
(3,099 Views)
