LabWindows/CVI
Error in STDIO.h file
I am making an application using LabWindows/CVI in which I have been using an ActiveX Server Library functions.
I encounter an error when I compile my program where I create/open a text file in read+write mode and try to write data to it.
The error is "Empty Declaration" and is shown in the STDIO.h file in the "typedef struct" FILE. which is used for /* Console handle for host stdio */
Can someone help me with this error.
Dwivedi
(3,017 Views)
Hello
Could you paste the line of code where you are using the file operation?
Bilal Durrani
NI
Bilal Durrani
NI
(3,017 Views)
Thanks Bilal..
But I already solved the problem.
Dwivedi
(3,017 Views)
