LabWindows/CVI
Error struct with Type Library and TestStand compatible
I have this struc
//ADDT Error
typedef struct Error
int code;
char *msg;
int occurred
}Error;
I generate a front panel automatically  from my .h and the help file and I integrate it in a Type Library but when I call it to TestStand I get a warning saying "Parameter x is an unsupported type. The type will be default to integer".
The help in TestStand is active as I intended.
I have already tried separating the error handling function and load the library and generate the .fp adding the .h instead of the type individually with ///ADDT Error.
I must say that when I configure the type manually to struct and Error in TestStand it works but am I doing something wrong?
The type library is supposed to do this automatically right?
Juan Navarro
Juan Navarro
Message 1 of 1
(2,573 Views)
