LabWindows/CVI
Error to execute *.exe files
An error message is appeared (see attached file) when I try to execute a .exe file by using LaunchExecutable or LaunchExecutableEx. What can cause this error?
(3,104 Views)
Hello Raybie
Are you able to launch calc.exe via the command line without using CVI? Which version of CVI are you using and on which OS. I tried this with CVI 7.0 and XP and calc seems to work fine. Make sure you have updated your OS to the newest service packs as well.
Let me know what you find.
Bilal Durrani
NI
Bilal Durrani
NI
(3,104 Views)
