LabWindows/CVI
Error when Building on CVI 2013 XmlReader fails to load
Thsi occurs during a code build under LabWindows CVI 2013 (FDS Version 13.0.2 (278) Windows 7 64 But Enterprise
The builds completes and is functional. However midway through the builds the error windows pops open and returns the following. This is a fairly recent change, I think, as the code (albeit being continuously changed with minor changes) used to build without erro windows. Possibly related to a Windows system update.
Please let me know if there is a known fix.
Error:
Error Details:
MetaToolbox::XmlReader::Load failed. SchemaPath=''
MetaToolbox::SchemaValidationErrorHandler::fatalError: Error at line 1:
Invalid document structure
Error:
Error Details:
(4,595 Views)
Hi;
Can you verify if the following files and folders exist?
C:\ProgramData\National Instruments\MIF\MetaInstaller\settings.xml
C:\ProgramData\National Instruments\MDF
It might be possible that the software needs to be reinstalled. In the following document you can see the instructions on how to repair it:
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
(4,574 Views)
The below file exists (438 bytes)
And the below folder exists (with 3 subfolders)
I can try the reinstall if that is the next step.
(4,563 Views)
