LabWindows/CVI
Error when build labwindows executable cannot find distribution LabVIEW 8.6, Disk 1
I'm trying to build an executable file but when I do I get the error "Distribution not found: Cannot Find distribution "LabVIEW 8.6, Disk 1. The path no longer exists.
I do not have any labview on my computer so I don't see why it should be looking for it.
Any help would be great.  Thanks.
(3,555 Views)
This thread addresses a similar situation. Basically, something you're trying to distribute depends on something that was installed (or most recently upgraded) from the LabVIEW 8.6 disk. So now, in order to distribute it, it needs to be copied from that disk. The "path no longer exists" message might indicate that a drive letter changed, or a network path is no longer valid.
Mert A.
(3,542 Views)
