LabWindows/CVI
Error writing workspace file
Hi all!
When I compile my CVI Project I get sometimes the following message: "Error writing workspace file d:\.... (File already exists)", and afterwards the question to continue or not (see the pictures).
When I continue, the existing .cws file will be deleted. A new cws file is created only on the next compilation. So, when I close CVI before the next compilation, the cws file is lost. Not dangerous but annoying.
I observe this behavior only since version 2013.
What's wrong?
Thomas
(4,490 Views)
Hi, Thomas!
It seems like my similar problem (http://forums.ni.com/ni/board/message?board.id=180&message.id=60376#M60376).
Unfortunately I never beat this (the "solution" doesn't work, the problrem persists). I try to set / change W7 directory access rights without success.
By some indicies I suspect that the cause may be somewhere in file access process on a multi-core computer (I have Dell VOSTRO with Core i7) - but I do not have idea how to verify this.
George
(4,481 Views)
Hi George,
yes, looks very similar.
And I can confirm, that disabling the auto backup feature does not solve the problem.
What I still can't understand is why CVI rewrite the cws (what is the workspace file) file every time the project is compiled. I think there is no need for.
Thomas
(4,474 Views)
Very strange! The error is sometimes displayed when the cws file does not exist.
Thomas
(4,446 Views)
Hi!
I unchecked the "Auto Save Workspace" feature in the File menu. This seems to fix problem.
Thomas
(4,423 Views)
