LabWindows/CVI
Evaluating Change in an Image
I am a programmer on FRC robotics team 1257, and I need to write some custom image analyzation code.  I want to loop through two slighlty different images and find the average x position of the change in green between the images.  I also want the average color of the area that changed (that part works).
// info1 and info2 contain valid data
rgb* pixelImage1 = (rgb*)info1.imageStart;
rgb* pixelImage2 = (rgb*)info2.imageStart;
for(int y = 0; y < info1.yRes; y++)
	pixelImage1 += 5;
	pixelImage2 += 5;
	for(int x = 5; x < info1.xRes; x++)
		// Do the processing
		if((int)pixelImage2->green - (int)pixelImage1->green > 150)
			if(y < 120)
				if(pixelImage2->green > 70 && pixelImage2->red < 150 && pixelImage2->blue < 150)
					averagePosX += x;
					red += (int)pixelImage2->red;
					green += (int)pixelImage2->green;
					blue += (int)pixelImage2->blue;
					total++;
		pixelImage1++;
		pixelImage2++;
	pixelImage1 += info1.pixelsPerLine - info1.xRes + 5;
	pixelImage2 += info2.pixelsPerLine - info2.xRes + 5;
 rgb is a struct that looks like this:
struct rgb
	unsigned char blue;
	unsigned char green;
	unsigned char red;
	unsigned char alpha;
Any help you can offer would be appreciated.  Again, we are finding the color correctly, but the x value (averagePos) is definitely wrong.  The nested if statements are just restrict our search in the image.
(2,978 Views)
Hi soystuff,
For all FRC related questions, you will want to use http://www.ni.com/frc
Click on the Discussions Tab to post questions relating to LabVIEW, FRC, and any of the utilities. If you are looking for help relating with C++ or Java, then you will want to use the corresponding forums for these languages. For example, http://www.chiefdelphi.com/forums/portal.php has a really good C++/Java community. In addition, US FIRST has a really good list of technical resources available for C++/Java programmers here: http://www.usfirst.org/roboticsprograms/frc/2013-Technical-Resources
Sincerely,
Aldo A
(2,954 Views)
