‎11-29-2004 06:13 AM
‎11-29-2004 09:51 AM
‎11-29-2004 11:14 AM
‎11-30-2004 09:09 AM
‎11-30-2004 09:58 AM
‎12-01-2004
09:12 AM
- last edited on
‎06-26-2026
09:12 AM
by
Content Cleaner
STA stands for Single Threaded Apartment. This a commonly use ActiveX term that describes how COM library initializes the threads concurrency model. Sometimes, ActiveX components misbehave if the incorrect concurrency model is set because they were not designed for that kind of use. By initializing the COM run time to STA, we basically say that the control was not designed for multi-threaded access. You can find more information about that here.
Can you post a small working example and the activex control you are using so I can test it out here? If you are not comfortable with posting the activex control on a public forum, you can contact our Application's Engineers by going here. This will probably go faster if we could look at some code we could run.
