LabWindows/CVI
Example for CVI created dll for VC calling
I use your cvi dll. I use the previouly attached VC2005 code to call it. There are still errors.
VCcallCVIDlg.obj : error LNK2019: unknown external symbols "__declspec(dllimport) void __cdecl RunDllUI(void)" (__imp_?RunDllUI@@YAXXZ),this symbol is in "public: void __thiscall CVCcallCVIDlg::OnBnClickedButton1(void)" (?OnBnClickedButton1@CVCcallCVIDlg@@QAEXXZ)  referenced.
1>G:\Mat_App\CVI\CVI85Exmpl\dll\simple\VCcallCVI\Debug\VCcallCVI.exe : fatal error LNK1120: 1 unknown external command.
I may need your VC2005 caller.
Message 11 of 12
(1,308 Views)
Problems still exist in VC caller:
The VC caller can call RunDLL() fo dll correctly. But when I add MyDLLStdcallFunction and MyDLLCdeclFunction, the app could not be compiled through. The error says:
1>VCcallCVIDlg.obj : error LNK2019: uninterpretable external sybol _MyDLLCdeclFunction@4,"public: void __thiscall CVCcallCVIDlg::OnBnClickedButton2(void)" (?OnBnClickedButton2@CVCcallCVIDlg@@QAEXXZ) referenced
1>E:\Mat_App\CVI\CVI85Exmpl\dll\simple\VCcallCVI_all\Debug\VCcallCVI.exe : fatal error LNK1120: 1 uninterpretable external command.
the dll program is as that provided by "NI device" of the previous reply.
The Mydll.h used by cvi dll project and the VC2005 caller is :
#include <cvidef.h>
//#include ".\CVIsystemDll\cvidef.h"
          /*    Here are the function prototypes suitable for including in a
                program which uses the dll. */
#ifdef __cplusplus
    extern "C" {
#endif
long int WINAPI MyDLLStdcallFunction(char * dummycharname);
long int WINAPI MyDLLCdeclFunction(char * dummycharname);
void WINAPI RunDllUI (void);
#ifdef __cplusplus
#endif
The VC2005 caller for RunDll and MyDLLStdcallFunction is:
void CVCcallCVIDlg::OnBnClickedButton1()
 // TODO: 在此添加控件通知处理程序代码
    /* Tell the dll to run it's user interface */
    RunDllUI();
void CVCcallCVIDlg::OnBnClickedButton2()
      tmpint = MyDLLStdcallFunction("Text buffer 1 being passed from CVI to DLL");
    //tmpint = MyDLLCdeclFunction("Text buffer 2 being passed from CVI to DLL");
 input1 = tmpint;
 UpdateData(FALSE);
Message 12 of 12
(1,259 Views)
