LabWindows/CVI
Example for timer control initialization programmatically ?
In user interface it is easy to generate the timer control callback, but how to make it work programmatically with Newctrl and etc. functions ? Is there available example how to do this ? I'm using Labwindows 4.0.1 version.
(4,125 Views)
I attach a simple project that creates a timer programmatically and uses it to flash a led on a panel. You can use it as a skeleton for you needs.
Regards.
Roberto
(4,125 Views)
I've just knocked this code up which might help you out...
If not, let me know...
Note: This was done with CVI 5.5 so I hope it works for 4.0.1.
Regards
Chris
#include
#include "a.h"
#include
#include
int CVICALLBACK timerCb (int panel, int control, int event,void *callbackData, int eventData1, int eventData2);
int iCount = 0;
int hPanel;
int hTimerID;
int hCountBox;
int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPSTR lpszCmdLine, int nCmdShow)
if (InitCVIRTE (hInstance, 0, 0) == 0)
return -1; /* out of memory */
hPanel = NewPanel (0, "Timer Test", 0, 0, 120, 120);
hCountBox = NewCtrl (hPanel, CTRL_TEXT_MSG, "Count", 20, 20);
DisplayPanel (hPanel);
hTimerID = NewCtrl
(hPanel, CTRL_TIMER, "Timer", 0, 0);
SetCtrlAttribute (hPanel, hTimerID, ATTR_CALLBACK_NAME, "timerCb");
SetCtrlAttribute (hPanel, hTimerID, ATTR_CALLBACK_FUNCTION_POINTER,&timerCb);
SetCtrlAttribute (hPanel, hTimerID, ATTR_ENABLED, 1);
RunUserInterface ();
return 0;
#define COUNT_MSG "Count:%d\n"
char szMsg[63];
switch (event)
case EVENT_TIMER_TICK:
iCount++;
sprintf(szMsg,COUNT_MSG,iCount);
SetCtrlVal (hPanel, hCountBox, szMsg);
if(iCount>10)
QuitUserInterface (0);
break;
return 0;
(4,125 Views)
