LabWindows/CVI
Example of ActiveX Control for Acrobat Reader
Is there example for using ActiveX automation control to launch & navigate
Acrobat Reader?
Thanks.
Jin
(3,459 Views)
Hi Jin
I have been trying to do this with LabWindows also but the ActiveX Controller made by LabWindows does not seem to work. It works fine from within LabVIEW but this is not much use to me in the long run.
IF you get this working please inform me
EXT-Peter.Willis@nokia.com
thanks and good luck
(3,459 Views)
