LabWindows/CVI
Example of code that use with MultiFileSelectPopup() function
Did you have example code that use with MultiFileSelectPopup() function ????
(3,103 Views)
If you bring up the function panel for the MultiFileSelectPopup function, and you right-click the "File List" parameter you'll find some example code that shows you how to use the function.
Luis Gomes
NI
(3,103 Views)
